Displays the log configuration for switch log settings, and for certain targets.
N/A.
This command displays the log configuration for all targets. The state of the target, enabled or disabled, appears. For the enabled targets, the associated filter, severity, match expression, and format appears. The debug mode state of the switch is also appears.
The following command displays the configuration of all the log targets and all existing filters:
# show log configuration Debug-Mode: Disabled Show Message Privilege: User (non-administrative) Enabled TLS Ciphers: aes128-sha256, dhe-rsa-aes256-sha256 Disabled TLS Ciphers: aes128-sha, aes256-sha256, dhe-rsa-aes128-sha256 Syslog TLS TCP User Timeout: Default Syslog TLS OCSP: On Log Target : memory-buffer Enabled : yes Filter Name : DefaultFilter Match regex : Any Severity : Debug-Data (through Critical) Format : MM/DD/YYYY HH:MM:SS.hh <Severity:Component.SubComponent.Condition> Buffer size : 1000 messages Percent Full : 100% (wrapping) Full Alert : None Log Target : nvram Enabled : yes Filter Name : DefaultFilter Match regex : Any Severity : Warning (through Critical) Format : MM/DD/YYYY HH:MM:SS.hh <Severity:Component.SubComponent.Condition> Log Target : console Enabled : no Filter Name : DefaultFilter Match regex : Any Severity : Info (through Critical) Format : MM/DD/YYYY HH:MM:SS.hh <Severity:Component.SubComponent.Condition> Log Filter Name: DefaultFilter I/ Severity E Component SubComponent Condition CEWNISVD - ----------- ------------ ----------------------- -------- I All ******** Include/Exclude: I - Include, E - Exclude Component Unreg: * - Component/SubComponent is not currently registered Severity Values: C - Critical, E - Error, W - Warning, N - Notice, I - Info * - Pre-assigned severities in effect for specified component Debug Severity : S - Debug-Summary, V - Debug-Verbose, D - Debug-Data + - Debug Severities, but log debug-mode not enabled If Match parameters present: Parameter Flags: S - Source, D - Destination, (as applicable) I - Ingress, E - Egress, B - BGP Parameter Types: Port - Physical Port list, Slot - Physical Slot # MAC - MAC address, IP - IP Address/netmask, Mask - Netmask VID - Virtual LAN ID (tag), VLAN - Virtual LAN name VR - Virtual Router Name, VRID - VR Identifier VRF - Virtual Routing and Forwarding Name L4 - Layer-4 Port #, Num - Number, Str - String Nbr - Neighbor, Rtr - Routerid, EAPS - EAPS Domain Proc - Process Name Strict Match : Y - every match parameter entered must be present in the event N - match parameters need not be present in the event
The following command displays Syslog TLS OCSP attributes (lines 8-11):
# show log configuration Debug-Mode: Disabled Show Message Privilege: User (non-administrative) Enabled TLS Ciphers: dhe-rsa-aes128-sha256, aes256-sha256, dhe-rsa-aes256-sha256, aes128-sha, aes128-sha256 Disabled TLS Ciphers: None Syslog TLS TCP User Timeout: Default Syslog TLS OCSP: On Syslog TLS OCSP Attributes: Nonce : On Signer ocsp-nocheck : On Override Server URL : http://syslogocsp:2022 Log Target : memory-buffer Enabled : yes Filter Name : DefaultFilter Match regex : Any Severity : Debug-Data (through Critical) Format : MM/DD/YYYY HH:MM:SS.hh <Severity:Component.SubComponent.Condition> Buffer size : 1000 messages Percent Full : 100% (wrapping) Full Alert : None Log Target : nvram Enabled : yes Filter Name : DefaultFilter Match regex : Any Severity : Warning (through Critical) Format : MM/DD/YYYY HH:MM:SS.hh <Severity:Component.SubComponent.Condition> Log Target : console Enabled : no Filter Name : DefaultFilter Match regex : Any Severity : Info (through Critical) Format : MM/DD/YYYY HH:MM:SS.hh <Severity:Component.SubComponent.Condition> Log Filter Name: DefaultFilter I/ Severity E Component SubComponent Condition CEWNISVD - ----------- ------------ ----------------------- -------- I All ******** Include/Exclude: I - Include, E - Exclude Component Unreg: * - Component/SubComponent is not currently registered Severity Values: C - Critical, E - Error, W - Warning, N - Notice, I - Info * - Pre-assigned severities in effect for specified component Debug Severity : S - Debug-Summary, V - Debug-Verbose, D - Debug-Data + - Debug Severities, but log debug-mode not enabled If Match parameters present: Parameter Flags: S - Source, D - Destination, (as applicable) I - Ingress, E - Egress, B - BGP Parameter Types: Port - Physical Port list, Slot - Physical Slot # MAC - MAC address, IP - IP Address/netmask, Mask - Netmask VID - Virtual LAN ID (tag), VLAN - Virtual LAN name VR - Virtual Router Name, VRID - VR Identifier VRF - Virtual Routing and Forwarding Name L4 - Layer-4 Port #, Num - Number, Str - String Nbr - Neighbor, Rtr - Routerid, EAPS - EAPS Domain Proc - Process Name Strict Match : Y - every match parameter entered must be present in the event N - match parameters need not be present in the event
Syslog reference identifier information was added in ExtremeXOS 22.3.
Which Syslog TLS session ciphers are enabled/disabled was added in ExtremeXOS 22.4.
Information about the Syslog TLS TCP user timeout value was added in ExtremeXOS 22.5.
OCSP check status information was added in ExtremeXOS 30.7.
Syslog TLS OCSP attributes were added in ExtremeXOS 32.2.
